I essentially have all of the parts needed (minus the drivetrain and the engine wiring harness) from the cancelled V8 Omega that was to be introduced for the 2001 year. I in a few months time will begin the swap, time permitting.
http://www.mediafire.com/?fbg4isemzzp
The subframe appears to be identical to the V6 excluding the altered mount plates.
Another subframe shot.
Engine mount and engine adapter plate closeup.
Engine mount has Mercedes logo and part number, (or from Mercedes supplier) and same as used on SLK, E-class and few ohter models.
This one is identical but has a GM logo.
Power steering fluid cooler. You can see this in the GM media pic posted above.
Manufacturers label on driveshaft.
Squished LHS primary to clear steering box.
I will post more pictures shortly.
