Beiträge von Omegab2010
    Mooin.
    Bekomm wenn ich im Teilemarkt was erstellen will ne fehlermeldung
    Fatal error: PHP warning in file
    /www/htdocs/omegafr/wcf/lib/system/io/File.class.php (41):
    fopen(http://maps.google.com/maps/ge…KCkWysYKYwXjenYAcRDNEysmA)
    [<a href='function.fopen'>function.fopen</a>]: failed to
    open stream: HTTP request failed! HTTP/1.0 403 Forbidden
    Information:
    error message: PHP warning in file
    error code: 0
    file: /www/htdocs/omegafr/wcf/lib/system/WCF.class.php (281)
    php version: 5.2.12-nmm4
    wcf version: 1.1.8 (Tempest)
    date: Mon, 16 Sep 2013 14:43:41 +0000
    request: /forum/index.php?form=RMarketplaceAdd
    referer: http://www.omega-freak.de/foru….php?form=RMarketplaceAdd
    Stacktrace:
    #0 /www/htdocs/omegafr/wcf/lib/system/io/File.class.php(41): WCF::handleError(2, 'fopen(http://ma...', '/www/htdocs/ome...', 41, Array)
    #1 /www/htdocs/omegafr/wcf/lib/util/FileUtil.class.php(365): File->__construct('http://maps.goo...', 'rb')
    #2 /www/htdocs/omegafr/wcf/lib/util/GmapUtil.class.php(56): FileUtil::downloadFileFromHttp('http://maps.goo...', 'rb', Array)
    #3 /www/htdocs/omegafr/wcf/lib/data/rmarketplace/mpEntry/MpEntryEditor.class.php(43): GmapUtil::reverseGeocode('http://maps.goo...', 'rgeocoder')
    #4 /www/htdocs/omegafr/wcf/lib/form/RMarketplaceAddForm.class.php(252): MpEntryEditor->add(Array)
    #5 /www/htdocs/omegafr/wcf/lib/form/RMarketplaceAddForm.class.php(108): RMarketplaceAddForm->save('Teiel f??r x25d...', 'Moin.???Bin auf...', '8078', 'Omegab2010', 'search', 1, 'DE', '41372', '10000', Object(MessageAttachmentListEditor), Array)
    #6 /www/htdocs/omegafr/wcf/lib/form/AbstractForm.class.php(90): RMarketplaceAddForm->submit()
    #7 /www/htdocs/omegafr/wcf/lib/form/CaptchaForm.class.php(104): AbstractForm->readData()
    #8 /www/htdocs/omegafr/wcf/lib/form/MessageForm.class.php(193): CaptchaForm->readData()
    #9 /www/htdocs/omegafr/wcf/lib/form/RMarketplaceAddForm.class.php(276): MessageForm->readData()
    #10 /www/htdocs/omegafr/wcf/lib/page/AbstractPage.class.php(90): RMarketplaceAddForm->readData()
    #11 /www/htdocs/omegafr/wcf/lib/form/MessageForm.class.php(237): AbstractPage->show()
    #12 /www/htdocs/omegafr/wcf/lib/form/RMarketplaceAddForm.class.php(331): MessageForm->show()
    #13 /www/htdocs/omegafr/wcf/lib/page/AbstractPage.class.php(46): RMarketplaceAddForm->show()
    #14 /www/htdocs/omegafr/wcf/lib/util/RequestHandler.class.php(64): AbstractPage->__construct()
    #15 /www/htdocs/omegafr/wcf/lib/util/RequestHandler.class.php(95): RequestHandler->__construct()
    #16 /www/htdocs/omegafr/forum/index.php(8): RequestHandler::handle('RMarketplaceAdd', Array, 'form')
    #17 {main}
    grüße
    naja 10l find cih schon nviel
    das hatte 'Falke dochs chon geschrieben :)
    edit: keiner sonst ne idee??? ist gut 1L auf 600km
    ZKD ist ok, jedenfalls was ich so sagen kann, halt kein lk im wasser und umgekehrt udn außem Auspuff kommt auch nix raus.
    Fußräume sind auch trocken, Kühler ist neu, da ist aber auch nix zu erkennen.
    Gibt es da evtl unterschiede von den Platte, hab ja die Pumpe samt Halter und Platte gewechselt, die ist aber aus nem 2,dti ich hab ja den dt.
    Das gumi ist noch ein gummi :)
    werd aber mal schauen ob ich noch neues bekomm
    Ansonsten gibbet dichtmasse, bekommt man zwar nie merh auf aber nunja :) ist dann halt dicht
    grüße
    edit: So habs jetzt mal geschafft, mir ist wohl das gummi immer ein wenig reingerutscht, war aber acuh ne scheiß abreit den kram zu zu bekommen, hat mir sogar nen Holzammerstiel gekostet, aber nun isser dicht :) Jetzt kann ich wieder volltanken wenns günstig ist
    Also beim Temp. anzeoge könnte auch der Stecker am fühler ab sein, oder du hast was am Kombi kaputt gemacht als du es raus hattest, evtl auch ein pin am stecker verbogen.
    Mit deinem ölstand, einfach mal den senosr ausbauen und sauber machen, könnte aber öl rauskommen also vorsicht.
    grüße
    Moin Moin
    Ich muss die Letzte zeit immer wasser anchkippen, finde aber keine undichte stelle, hab kein Öl im Wasser und anders rum, auch stingt es im behälter nciht nach abgasen, und qualmen tut er auch nicht, Kühler ist neu, auch die WAPU.
    Einer ne idee wos hin seiin kann?
    grüße
