change engine from 2,2 o 3,2
    ecu, gearbox, kabelbaum, brakes (just the rear brakes, the front one should be the same)! + ?break master cylinder? (i'm not sure, maybe there the same too)
    Max Power!
    He's the man,
    Whose name you'd love to touch!
    But you mustn't touch.
    His name sounds good in your ear,
    but when you say it, you mustn't fear!
    Cuz his name can be said by anyone!
    Einmal editiert, zuletzt von Max Power ()
